#149956
G'day - so I've started on all of this before discovering these forums, where I can see a wealth of knowledge.
My journey started with a Lightning McQueen from my sons grandparents who picked it up for a song at a garage sale.
Absolutely didn't work, diagnosed two motor failures and a broken steering servo. I found some great 15k motor and gearbox combos that lasted a few months with the existing controller, but the controller eventually melted and the cooling end of the motor colapsed on one side.. having a bit of RC experience, I decided it was time for a complete overhaul.
I've put in dual 120A ESC, sufficient battery to power it, 2x 3570 motors and replaced the controller with an arduino (considering all controls are now signal - all easy enough ) - and I'm just waiting on a pair of 5mm 10T pinion gears to arrive before I put it in. In the progress of doing all of this, it occurred to me that someone might benefit from my arduino code, or that someone might have made a better one already.. I'm super keen for any suggestions, I still need to wire up horn and headlights and all of that... and a bit smarter throttle control (if anyone knows a cheap way to make a linear throttle, the one I have in there is on/off ) and I still need to wire in RC control again.
Code: Select all
#include <Servo.h>
Servo firstESC;
int pos = 0; //Sets position variable
int current_throttle = 1500;
int current_reverse = 0;
int current_turbo = 0;
int last_throttlestate = LOW;
int throttlechangeMS = 0;
void setup() {
  firstESC.attach(5);
  firstESC.writeMicroseconds(1500);
  pinMode(7,INPUT_PULLUP);//throttle
  pinMode(6,INPUT_PULLUP);//reverse
  pinMode(8,INPUT_PULLUP);//turbo
    Serial.begin(9600);
void loop() {
  // put your main code here, to run repeatedly:
  int throttlepin = digitalRead(7) ;
  int reversepin = digitalRead(6);
  int turbopin = digitalRead(8);
  if ( turbopin == LOW ){
     current_turbo = 100;
  }else{
    current_turbo = 0;
if (reversepin == LOW && current_reverse==0) {
        Serial.print("we're in reverse \n");
        current_reverse = 1;
if (reversepin == HIGH && current_reverse==1) {
        Serial.print("we're no longer in reveerse \n");
  if (throttlepin == LOW ){
    if (last_throttlestate == 0 ){
      // we've just hit the gas
      Serial.print("we've just hit the gas \n");
      last_throttlestate = 1;
      throttlechangeMS = millis();
    int msDelta = millis() - throttlechangeMS;
    //we can ramp up at 50 per 100ms, up to 1700MAX
    if (current_reverse == 0){
      if (current_throttle < 1700 + current_turbo){
        if (msDelta > 100){
            if (current_throttle == 1500){ current_throttle = 1580;}
            current_throttle = current_throttle + 5;
            Serial.print("speeding up to ");
            Serial.print(current_throttle);
            Serial.print("\n");
    }else{
      if (current_throttle > 1300 - current_turbo){
        if (msDelta > 100){
            if (current_throttle == 1500){ current_throttle = 1420;}
            current_throttle = current_throttle  - 5;
            Serial.print("reversing to ");
            Serial.print("\n");
  if (throttlepin  == HIGH){
    if (last_throttlestate == 1){
      // we've just taken our foot off.
      Serial.print("we've just taken our foot off the gas \n");
      last_throttlestate = 0;
    //we can ramp down at 50 per 100ms, up to 1500
    if (current_throttle > 1500){
      if (msDelta > 100){
          current_throttle = current_throttle - 20; // brake 4 times faster
          if (current_throttle - 1500 < 20 ) {current_throttle = 1500;}
          Serial.print("brakeing to ");
          Serial.print("\n");
    if (current_throttle < 1500){
          if (msDelta > 100){
          current_throttle = current_throttle + 20;
          if (1500 - current_throttle < 20 ) {current_throttle = 1500;}
          Serial.print("braking from reverse to ");
          Serial.print("\n");
  firstESC.writeMicroseconds(current_throttle);
  delay(10);
