#150095
I have a Power Wheels Brute Force Camo. When in reverse or slow- nothing. When in fast- the left wheel only moves. I've worked on many Power Wheels. I like this model, but it is very difficult and time consuming to work on. Also, the battery indicator light isn't working.
I took the body (Green) off and got the the shifter. I took it apart and cleaned all inside. The switches looked pretty good. I put it back together and no change. It's a brand new battery. I also got to the gas pedal, cleaned up things and the connection looked pretty good and not rusty.
I don't know why there are 2 wires that go to each side of the front "suspension" mount. Maybe they are grounded on each side??
Thanks for any help as I am stumped. I saw another person on here had the same exact issue.
