By Jkilmurray
#150466
I got the lights done on the kids new rzr. Pretty much just eagle eye leds all the way around. 2 in each headlight. 1 in each roll bar light and 1 red one in each tail. I also used 2 red strip lights in each tail to give it a nicer look. Went with yellow strip lights in each wheel well as well. Ran it to 3 separate switches to control head/tail, underglow, and roll bar lights. Had to get the low profile 23mm eagle eyes to fit under lenses. Ended up using same in roll bar lights. Cut some plexi and silicones into the roll bar lights to set them back as far as I could to get better light output. Pics don’t really do it justice. Can’t really see the details in the lights.
By Jkilmurray
#150525
No diagram. Just ran all the rear lights to the center where the stock wires are under the little plastic cover. Ran the rear and the front into the battery compartment and ran to switches. On the light bar I drilled some holes under where they screw in and ran them inside the roll bar down and out. If you need any kind of pics I’d be happy to send you some. I didn’t mess with the terminal blocks or anything. Just ran wires direct.
