By johan
#151024
Search is not much help, the title words returned nothing on Search.
I have had no luck in finding a source for the 12V Perego AMP connector, there is no part number on the connector, only the AMP identity.
Google finds cables and wiring harnesses, but no connectors. Would appreciate the part numbers for both sides, and/or a source for both.
Thanks
Trailers
Peg Perego axle diameter
